A3 front end shake above 45.....
Hooper
Grand Rapids
I know there are threads about this but I can't seem to find them. I have tried to swap tires around and it has not changed. It feels like it is in the steering.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Check "toe in" and king pin bushings. MAybe make sure the steering box bolts are tight. I have seen the drag link needing adjustment too. Are the tires tread cupped? Etc
319
Lieutenant
57
Michigan
I had a minor shaking issue with mine at roughly 40-45mph. It didn't do it all the time though. Since my CTIS wasn't working and I didn't plan on fixing it or using it in the future I just removed the CTIS crap from the fronts and have not had an issue since.
Hooper
Grand Rapids
I will check all these things this weekend. I'm torn on the CTIS. I like things like that to be somewhat original, I just wish it was more reliable.
m816
Chatham, NJ
Hey Gimpy, I have an A2 here at the shop that has a slight shimmy at about the same speed. Goes away if I push it above fity/fifty five. I'm not sure about adjusting the shims on the king pins, I've never done that. I think if I do one side, I have to do the same thing on the other side? Is that right. I checked the play on the steering box and tie rods are good. Never done toe in on one either. Give us some pointers please. Not trying to hijack any thread but it goes with this I think
wsucougarx
65
Washington State
2/4 of my trucks have a pretty good harmonic bounce at certain speeds. Tires don't seem to change anything. My M923 doesn't like 40-42. My M109A3 doesn't like 30-34. They bounce around like crazy despite tires, alignment, and drivers.
motomacguyver
Eau Claire, Wi. USA
Cut and paste from a different post.
I had my CTIS stuff off the wheel and weighed the components at the grocery store.
The cover 3.57 lbs
The counter weight 2.82 lbs
The wheel valve with fittings and hoses. 1.75 lbs
4 lug nuts 1.38 lbs
4 regular nuts .45 lbs.
So if we figure (guess) 75 % of the cover weight (because it is pie shaped and most of the mass is at the outer edge)
2.6775 lbs
valve assm. 1.75
lug nuts 1.38
equals 5.8075 lbs.
minus 2.82 lbs for the counter weight
leaves a 2.9875 lb imbalance.
So, if you replace all of the lug nuts on the CTIS side of the wheel with regular size nuts (JUST THE ONES THAT HOLD ON COVERS OR VALVES). Than put all the lug nuts on the other side. That should get the imbalance down to around 2/3 of a pound. Still heavy on the wheel valve side though.
I think car guys use weights in 1/4 ounce increments or less. (for comparison) This is the very first thing I would do to help tame the wobble. The A2 guys probably don't have wobble due to NO CTIS
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
....... The A2 guys probably don't have wobble due to NO CTIS
Oh yes we have....; and usually starting at 40mph and over..., although not to such extremes as the A3's do.
On the front axle, all possible unbalance plus run-out, combined (drums + wheels + aged NDCC tires) can simply be too much; causing wheel hop at least, and sure ending as shimmy if anything related to the steering got enough play.
Message to all: (Even if the military didn't care) - KEEP YOUR WHEELS /TIRES BALANCED: it reduces wear and fatigue of front axle and steering components and enhances everyone's SAFETY!
G.
steve6x6x6
37
Winter Haven, florida
The cover 3.57 lbs
4 lug nuts 1.38 lbs
2.6775 lbs
valve assm. 1.75
lug nuts 1.38
equals 5.8075 lbs.
All of these items do not weight the same because they are at different raduis on the wheel. I set up a hub to staic balance and added 14 ounce of equal, from 0 to 62 MPH is smooth as silk, better than any car.
319
Lieutenant
57
Michigan
I still have the CTIS components on the rear tires and it doesn't seem to have any ill effects on the ride. Did you balance all of the tires or just the fronts?
Hooper
Grand Rapids
Kind of ressurecting an old thread, but did you ever resolve your issue?
Not exactly. The research I did lead me to the tires being out of balance. I was going to have them bead balanced but decided to sell the truck and buy a M923A1 instead. Best thing ever, the 923 is awesome, no CTIS=no vibrations. The guy who bought my A3 was an onion farmer and vibration issues at top speed did not concern him. There are several threads in here where people have made additional weights to fit behind the counter weight, and there is a thread which has you add 6 lug nuts in key places. Hope this helps.
