AC Killowatts and AC amperes gauges on TMSS
Mk23
81
Port Angeles, WA
New to me 2007 TMSS med. Getting things going when I noticed that the 2 above mentioned gauges don't reset to 0, even when fully disconnected. They behave as this is their 0. Meaning when full 18kw is engaged on ECU, it shows 23kws. Anyway to repair them?
I know with 803a series, I have seen people use commercial digital gauges sometimes. Amy reason not to switch it out? I can't seem to find this same analog ones even with a part number. Any suggestions for appropriate replacements?20220328_190644.jpg
G744
3,723
Hidden Valley, Az
Have you tried to zero them with the screw in the lower part of the cover?
Gently turn the screw and see if the pointer responds.
DG
Mk23
81
Port Angeles, WA
That is an excellent idea! I didn't even know that was a thing, until you just mentioned it. I will most definitely give it a go.
DG
Guyfang
23,349
Burgkunstadt, Germany
6625-01-567-9791 or 50365A100A for AMMETER
6625-01-569-7929 or 50351MA-0-30KW for WATTMETER
NSN: 6625-01-567-9791
Part #: 50365A100A
Tech data.
END ITEM IDENTIFICATIONG06AAS
INDICATOR TYPEDIAL W/POINTER
III INSTALLATION DESIGNPANEL
CIRCUIT ATTACHMENT METHOD AND QUANTITY2 THREADED STUD
PART NAME ASSIGNED BY CONTROLLING AGENCYANALOG PANEL METER,0-5A AC IN,0-100A SCALE
SPECIAL FEATURESINPUT:0-5A AC;SCALE:0-100A AC;DIMENSIONS:3.500 INCHES X 3 1/2 INCHES
PROPRIETARY CHARACTERISTICSPACS
Company that supplied it to the Military: Panel Components & Systems, Inc.
NSN: 6625-01-569-7929
Part #: 50351MA-0-30 KW
Same supplier.
That was all I could find in a quick look see.
Mk23
81
Port Angeles, WA
Thank you for looking that up!
Part #: 50365A100A
Tech data.
Same supplier.
Poccur
125
Roanoke, VA
When your system was made those meters were purchased from:
They can sell you replacements if you need.
Regards
Poccur
Mk23
81
Port Angeles, WA
Regards
Poccur
Thank you, much appreciated!
