Accelerator for M35A2
I have to use a lot of pressure with my foot to push down on the accelerator to give my deuce fuel to give it forward momentum. My foot gets tired keeping it pushed down. Is there something I can do like installing a spring thats less stiff? Anyone have a suggestion? Hope this isn't a stupid question. Thanks!
Warthog
245
OKC, OK
Sounds like you have some binding in the linkage or the wrong spring installed.
Remove the linkage at the injector pump and check the movement.
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
My peddle hinge was seized. Have you tried moving it by hand with the truck not running? All I had to do was pull the bolt/pin and clean it up.
Heavysteven
11
Hickory Flat Ga
Old thread but I have same issue. Accelerator spring came off and when I tried to reuse it broke in half. Looking for a replacement thinking stainless steel. Anyone find an alternate decides oem?
Going to try mcmaster in the morning.
