accelerator pedal
westfolk
156
PA
Check to see that nothing is against the rod going to the IP. If not oil that baby. Still nothing....unhook it from the IP...is the pedal fine then? Pull on the arm that the pedal rod hooks to.....is that sticking?
westfolk
156
PA
Thanks....I liked my old avatar, but then after moving the Komatsu I thought that looked pretty good too.
1,807
Check the rod that goes through the floor. They smotimes hit the sheetmetal at a certain part of the arc the travel.
