accessories ran off deuce air supply
F18hornetM
10
Ocean City, Md
I am not sure what the CFM is from a deuce compressor, but I dont think its enough to run a media blaster or an air tool for very long. It takes it awhile to pump up its air tanks and they are small. Just my 2 cents worth.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Paint gun maybe, if its hvlp. Blaster, no way. Every tool has a cfm rating, you need to look at that and size your compressor accordingly.
If you are looking at getting a home compressor, you need at least 10cfm at 120psi, 15or more is better.
demonhunter77
alabaster/alabama
Thank you guys. Looking at the shop compressors with 15 cfm. Seeing as how i just dropped 2 grand on parts for my deuce and want to spend about 2 more grand on wheel and tire upgrades, i guess i better rent a blaster compressor combo. You guys saved me some frustration. :) thanks again.
gimpyrobb
27,785
749
Cincy Ohio
If you are looking, check ebay, craigslist or even GL for a champion compressor. I have been extreemly happy with mine. I don't see the value in buying new for one of the name brand compressors.
wreckerman893
Possum Connoisseur
15,621
2,025
I got the biggest compressor that Tractor Supply sells (the Boss Lady works there) and it has served me well. You can catch them on sale and watch for "Friends and Family" sales.
That being said media blasters are air hogs....even a big compressor will work to keep up with demand.
I have a small bench top blaster box for small stuff and I've blasted some small panels and other objects. If you are going to do a whole vehicle check around for guys that do mobile blasting.
You need a good vent system and other safety gear......you do not want to get silica into your lungs.
A duece will run a paint gun....we did it all the time in the Army to spot paint trucks. You will need an in line water filter to keep moisture out of the gun. You will also need a regulator to keep the volume constant. You can usually get them at NAPA or an automotive paint suppy house.
demonhunter77
alabaster/alabama
I read your post wrong. Sorry sir. Lol. Would i be running the champion compressor alone or in tandem with air.from the glad hand on the deuce? My father (the sarge) donated the safety gear. No silica though. I was going to use soda.
Wreckerman----i will surely be looking out for those items at the auto parts store. Thanks.
welldigger
15
Benton LA
Soda may not cut through that paint. I'd be looking for walnut shell. Another media that has served me very well is play sand. Its cheap but you have to sift the gravel out.
