Accessory Wiring - M1097R1 / Dual Voltage 200A - 24v vs 12v
Ramzi
49
Texas
I would like to add some accessories and so far everything Ive been able to purchase is 12v / 24v compatible (LEDs, Bluetooth, amp / volt meters etc).
If I choose to operate only 24v accessories, is it best to pull power from the forward most bus bar "positive " post in the battery box?
Then run that to a power distribution block (with an appropriate breaker near the post)? Or is there a better way to pull 24v?
If I decide to operate in the 12v world - are there any down sides to installing a step-down in a similar configuration as above? But at this point I don't see a real need to use 12v
Also, currently I do not have any wiring attached to the 14V tap on the front of my voltage regulator.
From what Ive read, attaching an appreciate wire from the 14v tap to the "positive" post on the rear battery will help keep the batteries in balance.
Is this really that simple?
Mogman
8,864
Papalote, TX
Your plans sound good so far.
Yes it is just that simple, I would use at minimum a #8 wire, although I am not 100% positive you do not need some 12V load to make it work properly.
Ramzi
49
Texas
So run the wire for the VR 14+ tab to the rear "+" post
Then tap the rear "+" post for a 12v bus bar and run something off that.
While tapping the 24v accessories of the front 24v bus bar...
Does that sound like a good plan?
Mogman
8,864
Papalote, TX
As long as you keep the 12V load relatively small, 10A or so cont. would be my limit, 20A int
The reg. is said to be good for 50A but I would not try it.
If you have any large 12V loads use a 24V-12V converter
