Add Winch to M923
Dmaxcc6spd
KY
Has anyone added a winch to an M923 truck? What parts are involved? Are the parts hard to find? How much work is it?
Thanks for any feedback.
BKubu
1,124
Gaithersburg, MD
I personally think you will be better off finding an M925. It is possible that you'll find a kit cheaply. With that said, my experience when looking for a winch kit (that I did not buy, by the way) was that they run in the $1200-1500 range. I am not sure all of the parts that you'll need, but at a minimum the kit involves: the winch, frame extensions, hydraulic hoses, hydraulic tank, PTO, and controls for the cab. Where you might luck out is with CSMDAVIS. He has parted out quite a few trucks and he may have a complete winch kit. I'd PM him...or, failing that, just look for an M925 and have one of each!
91W350
57
Salina, Kansas
Are you lucky enough to have one of the M923s that have the controls and hydraulics already in place? I think they were originally 925s that had the winches pulled. Some of them have 923 data plates.
Dmaxcc6spd
KY
I have not yet acquired a truck. I found someone who wants to partner with me, but he would prefer a winch truck. They seem to be harder to find and I would prefer to acquire from somewhere reasonably close to home.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Pretty sure I have the pto you would need. DH might have the winch. You'd still need frame exts., the hyd motor, and the pump though.
91W350
57
Salina, Kansas
I had a rancher today tell me that the Allisons have to be set up for a PTO, not all Allisons have the internal drive gear gear. It does not make sense to me, looks like they would all be set up to drive a PTO. At any rate, maybe somebody who knows will chime in. Glen
BKubu
1,124
Gaithersburg, MD
Glen, I don't know that this is false, but I believe it to be. I have never heard of different Allisons for this series. I suppose it is possible that you learn something new everyday. I will await confirmation, but my initial thought is your intel is incorrect as you suspect.
hummerjohn
Freehold NJ
Your info is half correct. All Allison MT654 as used in 900 series, MT653 and MT643 have the gear to drive a PTO but not all AT545 as used in M35A3 and other civilian trucks have the drive gear. Also not all overdrive 1000,2000,2200,2400 and 2500 series have drive gears
BKubu
1,124
Gaithersburg, MD
The winch that John is offering is fair value, but that also makes my point...buy the whole truck from him!
mattburgey
tennessee
I would be interested in seeing some pictures of the 4000 dollar 925 been wating to upgrade to a 5 ton for quite a while.
jesusgatos
on the road - in CA right now
Was looking for information about what adding a winch to an M939 would entail and this is one of the only threads I was able to find. Is it as straightforward as sourcing and installing all those components? No special transmissions or any other deal-breakers? Prices atill around $1500 for complete winch conversion kits?
Gunzy
66
Roy, Utah
I just bought a complete parts truck(M932A2) just for the winch and a few other parts. Planning to start working on the switch over at the end of September.
