redneckepj
- 0
- 0
- Slaton tx
Our Fire Dept. receintly acquired a 1993 M35A3 from the DOD for converting into a Brush Truck. We have done a lot of research on running our 12 volt equipment on the 24 volt system (converters, ground isolation, dual charging alternators and adding a seperate alternator for a independent 12 volt system). We have decided that the latter is the most cost productive as well as railure resistive method. Here's my problem: All the information that we have found is for the older multi-fuel engines. Ours is equipt with a 3116 CAT engine and sports a single cerpentine belt as well as minnimum room to mount the second alternator. HELP!
