Adding a turbo to 1984 M936
98G
Former SSG
4,813
I have a turbo on an NH250 (in an M818 - same engine)
Some things to consider -
The NH250 isnt designed for a turbo and lacks the oil squirters. Melting a piston is a concern.
The wrecker weighs almost 40k empty. This means it's going to be a slug no
matter what. The additional weight will make it that much easier to hit temperatures capable of melting a piston.
The Allison transmission wont like the additional torque. This'll be exacerbated by the wrecker's weight.
That said, the turbo makes a pronounced difference on being able to hold speed on hills. It also improves fuel efficiency. My nonturbo NH250 trucks get 5-6mpg. The one with the turbo gets 7-8mpg.
WildernessJeep
91
Huntsville, Texas
I just don't see the benefits offsetting the costs. As you said, it's possible, but I'd need to upgrade a lot more than just a turbo. For money spent, I can upgrade other things. We don't have hills around here, and I won't tow anything too heavy very far with this truck, so I'll pass. Thanks for the input!!
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
Turbo, exhaust manifold, you can wrap the intake around with piping to use the standard intake. Or I have a intercooler set
Ive got a cheap running Big Cam I 400hp cummins that swaps in. Need to refab the front mount crossmember thought. Bolts to the transmission the same.
