Adding AC to a CUCV
mangus580
282
Western NY
For the most part, you could use all stock GM parts from a civvy truck. The problems you would have are
  • Rear Battery tray
  • Drivers alternator
  • Dash radio mount
  • volt meter
  • blackout light switches
Other than that, you should be set.
BKubu
1,150
Gaithersburg, MD
...add to the problems the ducting... You'd have to use either the defroster or the heater ducts...which are not optimal for cooling.
Bruce
Olney, MD
mangus580
282
Western NY
Yeah, I was assuming the ducting was 'part of the kit'. that was why I made mention of the dash stuff that would be a problem.
I wonder how much of a PITA puting the ducting in would be...
1,131
I really think an aftermarket air setup, such as what's offered by Vintage Air to be the best avenue for a CUCV. Will work better (cooler and flow more air) as well.
MATT
Colorado
We aquirred 2 1008 from AZ I believe, with a AC system. It has a underhood compressor and a large box on the passenger floor area.
225
edmonton ,alberta
air...
I personally think the system from vintage air is the best bet...the complete kit has all the ducting,switching etc and they have a version that can be switched mechanically...no vac doors required.
The ducting runs under the dash,and the switching replaces the duct lever panel for a stock look.
one extra benifit....i think that the vintage air system dosn't have the factory "a/c hump" that sticks out the fire-wall...you can keep the cucv battery trays.
NCINIRATOR
Maryland
RE: air...
Now that summer is upon us I'm thinking about the AC thing too. I don't have the time or patience to jack around with tearing out the dash and all that.
vintage air is nice, but I just looked at some stuff from carrier. I figure buying the external AC unit that sits on the top. The cover on the CUCV could be cut for the external AC unit.
Whaddaya think? http://www.airv.carrier.com/details/0,2806,CLI1_DIV46_ETI9772,00.html
1,808
RE: air...
You going to run a generator in the back? Those look to be 110 units and draw 20 amps.
NCINIRATOR
Maryland
Oh, did I forget to mention that I have no clue about those external AC units...I have seen them on vans, so why not slap one on a CUCV! :?
dilvoy
25
San Francisco, Ca.
There is a company called "Red Dot" that makes A/C units for all sorts of vehicular applications, they make them for on and off road usage and sometimes even have them in 24 volt as well as 12 volt. I have no affiliation in this company, but I am looking at ways to install A/C in my Humvee.
devilman96
17
Boca Raton, FL
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=1083&highlight=adding+ac
There is a whole blurb about it there...
http://www.danhard.com/sub11.htm
This is the one I bought (frist unit) but I was willing to fight through the hassle of both heat and AC with defrost. The cool thing about the comapny is they will build to your spec if you need it... The unit I bought was 12V and they swapped it over to 24V for me. IF you take the time to look through all of the stuff they build you will see there is about 100 ways to install AC into trucks that you would never picture possiable.
http://www.danhard.com/sub24.htm
