Adding An Auxiliary Fuel Tank - M1028
combat jump
Raleigh, NC
I’ve decided to add an extra fuel tank, just as some stock Chevy trucks came with. So far, I know that in factory original dual 20 gallon tank trucks, both tanks are identical, but use side-specific sending units. Also that LMC Truck carries almost all the parts needed. Finally, that my local wrecking yards are a good place to look for parts cheaply (though its more work).
I am going to share a step-by-step installation. It will probably take some time, so please be patient. When done, I hope to have documented a completed “How-To” that anyone can follow.
I started with the filler door. My M1028 has only one on the left side, of course. This is a part that you can’t just “order”. I don’t like the idea of having to fill the second tank from inside the right rear wheel well. I found a dual tank 1984 Chevy K30 at the wrecking yard, and cut out the entire filler door.
I used a battery drill to make pilot holes to start a hacksaw blade. Despite what the photo shows (some fancy hacksaw blade tool), turns out that the teeth wear quickly (used 18, then 24 TPI). The tool only lets you take advantage of a small section of the entire blade. I ended up holding the blade with pliers. I got the door cut out in an hour, with three blades (but wished I had brought more).
Again, there’s no way to add a filler door unless you cut one out of a donor truck. This would have been a good excuse to buy one of those DeWalt battery angle grinders with a metal cut off wheel.
I haven’t decided how to attach the door to my truck yet. Of course I’ll cut a hole first, then maybe just rivet it into place. Or get fancy, and weld it. I’d like to see how others have done this.
readyman
Elk Grove Village, Illinois
I've used one of them hacksaw blade holders... forever. Till about a year ago when I sprung for a battery recip saw.
I laughed at the battery reciprocating saws when they first came out and said who'd ever have a need for them. But after getting one, I probably use it as much as the drill. Home, yard, farm, garage, anywhere, but it eats blades a lot faster than my hand hacksawing.
1,806
I've cut out 2 of these at bone yards. I did a tool thread on the Milwaukee Hackzall M18 powered. I can cut one of these out in less than 2 minutes. This will be a good thread.
combat jump
Raleigh, NC
I pulled the trigger on a DeWalt 20 volt angle grinder with 4 amp batteries and a metal cut off wheel.
I'm heading back to the wrecking yard again this weekend, and I'll make that donor truck my bitch.
combat jump
Raleigh, NC
Went to two junkyards today. I found a fuel filler neck from a diesel that I will use. It came from a truck missing the bed, so an easy part to remove. Other parts are elusive: All the fuel tanks are punctured to drain when they arrive. I'll have to buy a new tank. I've also decided to buy the tank holding brackets - the ones I've seen were either damaged or badly rusted.
nyoffroad
674
Rochester NY
To bad your so far away from me, I have a complete tank setting outside that I would've given you.
I put the dual tanks in 2 other trucks and found that useing metal adhesive was the easiest way of fitting the filler door cut out. I did one and got hit about a week later and the adhesive held up better then the rest of the box side!
I just ground the outside of the doner part and the inside of my box side mixed the glue and and used a couple screws till it was dry, then a little bondo.
combat jump
Raleigh, NC
nyoffroad,
I appreciate thought - thanks!
I've been so wrapped up with work that my tank hasn't got the full attention. Here's what I've done lately: Researched for a tank and sending unit - called LMC Truck because their catalog lists almost exact parts/years that I need. They told me their right side sending unit would not fit my year tank. So I found the parts on O'Reilly's web site, and ordered the tank and sending unit. The Sender appears to be for the driver's side, though, as it points the hoses to the right when installed. I will contact them, and maybe send it back, then post updates when I have progress.
Regards,
CJ.
Csm Davis
381
Hattiesburg, Mississippi
Well you can do what I did just swap out the whole bed.
combat jump
Raleigh, NC
CSM Davis,
That's one way to do it! Not my first choice, though. I'd have to find a bed in decent shape first, then remove and unbolt everything from my M1028, re-drill the holes for the shelter tie down hardware, then paint it. I'll do it in small steps instead. I hope to make progress over the Christmas holiday.
Regards,
CJ
Csm Davis
381
CSM Davis,
Regards,
CJ
That's exactly what I am doing.
xenocath
searching.............
193
Glen allen, VA
i added the tank, Pollack valve, and wiring then auggered out the filler neck from unleaded to diesel sized from my old 3/4 ton 81 chevy but stupid me forgot to cut out the door before the wrecker arrived so I just cut out a square hole to be filled in the future when a door falls into my lap works well so far with a big American flag magnet to cover it up
TVOLLMER
Sandy, OR
I am also considering the dual tank. One question I had was about the fuel return lines. Is there a switch/valve to go in the return lines so they return to the tank being used? Can you use the same style switch/valve as you would for the pickup line?
Csm Davis
381
Yeah you have a couple options you can use the stock Chevrolet twin tank setup or the manual valve off of a five ton with twin tanks which is probably the direction I will take because I owned a brand new 83 with the stock setup and it stinks!
combat jump
Raleigh, NC
Progress Update...
I cut a square hole into the right side of the bed to accommodate the filler door I had previously sawed out of a donor truck at the wrecking yard. Key point here is to carefully measure the location of the main fuel filler door - the auxiliary door will be the same. I cut a hole just large enough for the donor door to drop in flush. I then marked and drilled the door flange for 1/8" medium length steel rivets. I finished with rattlecan desert tan paint, matching what I had painted the rest of the truck a few years ago.
I had considered welding the door into place, and making it all pretty with Bondo, but this installation is closer to what an ambitious motor pool Sergeant would do, and the rivets look right at home on the CUCV.
The fuel tank is from O'Reilly's Auto Parts. I could not tell if it was galvanized, so I painted it with Rustoleum (with a brush). DSCN0146.jpg
The sending unit is also from O'Reilly's. This is a different part from the main tank, as when installed, the tube ends point inboard toward the center of the truck.
The six port valve took some research, as what I found on eBay did not seem to be compatible with a 1985 K30. I found this one on Amazon. The 6 port (five useful) plug was a separate purchase. The selector switch I pulled from a donor Chevy truck.
Ok, that's the update. I'll next be ordering tank brackets form LMC Truck.
-CJ.
