Adding in-tank fuel pump to M818
JasonS
139
Eastern SD
I have an M818 with NHC250, is there any reason not to install M35A2 fuel pumps into the M818 tanks? I realize that the opening in the tank needs to be enlarged but it seems that supplying pressurized fuel would be beneficial. I already have all the parts so cost is not an issue.
msgjd
3,170
upstate ny
Multifuel truck in-tank pumps are getting fewer/ farther between, and costlier .. As mine fail and I ran out of spares, i first went to using 24v aircraft in-tank pumps.. Often the same maker, a similar design, somewhat cheaper, but they need time invested to retrofit the wiring and make it fit the existing truck cage.. They are not "plug & play" , they are getting hard to find too, and most of them are in "used" condition.. The gov't is no longer fielding trucks with a multifuel-style in-tank pump, thus pumps are not being made for the gov't .. Used decent pumps are also getting scarce unless you have parts of your own.
For a couple "i don't care if they stay 100% original" 5-tons, I installed a Carter 24v heavy-duty 3/8" inline pump ahead of the filter.. Of course on your M818 you will either need one pump at each tank with separate switches, or adapt just one pump into the main line between your tank selector valve and filter , and tie into your accessory switch load-side wire.... I don't have their part number handy but they come as a kit with a mount and vibration isolators .. Got them on e*ay.. The pump pressure (@14psi) and fast action makes up for the 3/8 inlet/outlet size of the pump .. They do a good job at filter changing time, which is the only reason I did it. Those two trucks sit very long periods and go through filters whenever put to work for a week straight.
In over 45 years of trucking I have never seen any 855ci PT-pump cummins engine , military or civilian, of any HP, that had an inline or in-tank pump .. I still have a few commercial 855's out in the yard (NTC230, 290, 315, 350) and ran a NTC400 for awhile .. The only time an in-line or in-tank pump is beneficial on a PT pump engine is at filter change time, most-especially the M809-series.. There are in-line hand primer pumps out there , usually with a spin-on filter base setup , if you consider other options ..
Cummins PT pumps, as-built , do not need pressure feed and probably is no better for it if it had pressure feed.. Adequate lubrication in the fuel is what they need today.. Lastly, always felt they should have an inline check-valve immediately after the filter(s) and at the fuel tank(s), but none of what ever saw or owned did.. .. For a very long time I have been meaning to try check-valves "someday when I get time."
:rolleyes:
JasonS
139
Eastern SD
I have six of the nice fuel pumps that were on ebay several years ago; not an issue. I can use the fuel level switch/ relay to control which pump is on.
What I am wondering if there is any technical negative to feeding ~7psi to the PT pump.
WillWagner
2,584
Monrovia, Ca.
Absolutely no reason for it. The pump has a 1-3/4 inch positive displacement pump on board. It is capable of sucking a column of fuel ten feet vertically before it needs help from a transfer tank.
It makes no more power and is a potential failure point.
EDIT, 1 and 3/4 inch gear pump, sorry, getting old!
msgjd
3,170
upstate ny
I had a feeling your initial post was hinting at that, between the lines .. I don't have any idea if positive pressure would hurt a Cummins PT pump or not .. The pumps I use on two of the M809's are of the feed-through type, thus they stay turned off at all times except for filter changes
