Aervoe Product
steelandcanvas
85
Southwestern Idaho
I have just used Aervoe Industries #595 Undercoating and Sound Insulator. It's rubberized and flexible, quick drying corrosion protectant. Comes in a 15oz. can. I used this to paint (cover) my battery hold down brackets on my Deuce. Works well, went on thick and covered very nicely. If my battery box had more metal in it, I'd cover it also. Thought I would share this to see what ideas you guys can come up with for this product. Oh I almost forgot, I did the battery box on my 5th wheel also, very pleased with the results.
WillWagner
2,729
Monrovia, Ca.
Can you snap a pic of what you coated? Wonder if it would work good for under the fenders and inside the engine compartment.
steelandcanvas
85
Southwestern Idaho
Will, I'd be more than happy to. I'll go out to the shop tomorrow and snap a few of my battery hold-downs. I think it would work great on fenders and around the engine compartment, however it might not be as cost effective as bulk spraying with a gun. The coating goes for almost $5 for a 16oz can. I think for small stuff and spot coatings you might be OK. Should check prices on bulk coatings.
jatonka
87
Ephratah, New York
Aerevoe coating
So what Aerevoe color turned pink? Just wondering cause I've used their paint for 10 years now, all the trucks live outdoors and none of mine are pink yet.
Mike_Pop
NJ
RE: Aerevoe coating
ALL of my vehicles painted with Aervoe are gray. Aervoe is the worst paint that I have ever used. Wherever the sun hits the paint, it will turn.
cranetruck
75
Meadows of Dan, Virginia
RE: Aerevoe coating
Mike and Mike, which paint number and how long before turning pink or gray.
My Aervoe 997B still matches fresh paint after 14 months of outdoor exposure.....
Thanks for sharing, John.
Mike_Pop
NJ
RE: Aerevoe coating
Bjorn,
I don't remember the paint number but it was the forest green. My stuff turned gray after two years. I've used both the spray cans and the gallons.
mangus580
282
Western NY
RE: Aerevoe coating
Mine is the 383 'clone' color. Whatever that turns out to be....
Mike... sorry I didnt listen before :-(
I even followed Aervoe's suggestions word for word (talked to them on the phone worried about the issue).
steelandcanvas
85
Southwestern Idaho
Re: RE: Aervoe Product
Here's the photos Will. If you'll notice, it dries to kind of a "wrinkle finish". I just wanted to stop the corrosion problem. These items were bead blasted, primed, and coated. I think I'll do the same thing to the hold-downs on my Dodge Cummins also. :idea:
