- 4,289
- 1,775
- 113
- Edmond, Oklahoma
I have hit a search wall.
I am replacing the seals and bearings on the O2 trailer I recently recovered.
Have found all the parts:
Bearings/Races, new nut, caps, etc
EXCEPT the grease seal!!
This generic wheel is used on everything from hydraulic test stand to air compressors to warehouse carts to O2 trailers, etc. including the NF-2D light tower I own.
I could pull off a wheel to see if there’s a p/n on it but will do that as an absolute last resort.
I’ve got the parts breakdown and p/n list from a TM
Problem is the number for the seal doesn’t cross reference to anything, other than a different manufacturers part number using the same NSN.
I’ve tried National seal, SKF, Timken, NAPA nd so on.
No luck.
The numbers on the seal itself also don’t cross reference to anything.
I’ve searched the threads with no luck.
What seal are you guys using on this wheel??!
No luck.
