affects of run on starter
MT4222
Plymouth/MI
Recently I experieced the dreaded run on starter. I did the doghead relay mod and replaced the starter. Now my I have no voltage. What is going on? I am able to jump it with my deuce and it runs but my volt gauge shows far left in the red. What do I need to replace change or repair?. By the way my light bulbs for the exciter circuit are not burned out but they no longer work. Where can I get the parts to rebuild the alts now that cucv electric isnt taking orders? Thank you very much
1,807
Fusible links weren't mentioned, I'd search there first.
Warthog posted the name of a company that lists the kits. Under advance search use keyword alternator, select the CUCV forum and select posts made by Warthog, should net you the contact info.
Warthog
231
OKC, OK
The 24v fuse is at the very bottom of the fuse box. The fusible links will behind the rear battery. They may be split, burnt, bubbled or they may look perfect. Many youtubes show how to check them
Do you have a multimeter and know how to use it?
MarcusOReallyus
816
Virginia
That's a good thing. You are miles ahead of some other folks, then.
Check the stickies at the top of the forum, too. There's a ton of good info on this issue.
swbradley1
Modertator
1,695
Dayton, OH
We were just discussing effect and affect at work the other day and how I rarely get them correct.
Thanks Mr Grammar
(No I am not kidding...)
1,176
And in the step by step troubleshooting section of the -20TM.
