Aftermarket fuel filter with drain
Finnegan1008
164
Connecticut
My new to me truck came with an aftermarket fuel filter that has a little petcock at the bottom to drain.
should I be cracking this drain periodically to check for water? Will doing so introduce air into my fuel system? Should I crank the engine while doing so or just let gravity work
5 Ton John
42
Mississippi
Yes you should drain it every so often and let the water out of it. If a lot of water comes out, then do it more frequently. If not then less frequently. Don't run the engine while doing this.
