Aftermarket LED lighting for HMMWV
FFesco
New York
Has anyone used any of the aftermarket LED lights sold online? Any recommendations?
How about wiring?
porkysplace
1,487
mid- michigan
How about wiring?
Yes people have used them.
Yes they need to be wired.
You probably need to be more specific of what kind of lights and how you want to wire them.
FFesco
New York
New to using forums as well as not very good with automotive electronics! I’ve searched a few lights that will fit the way I want, but trying to understand the wiring.
Basically, can’t I cut the stock wire connector (rubber boot) and just solder it together or should I do it another way?
suzukovich
141
Gibsonton Fl
No HUMVEEs are 24v systems
Any aftermarket has to be 24v. You can find 24v bulbs or light out there with the mil connectors.
Sent from my SM-J727U using Tapatalk
Skrilex
Banned
356
Portland Oregon
In my experience the lifespan claim can be debatable. Also, amp draw is not really an advantage as most of the time they end up putting resistors in the bulb so that the functions still work and vehicle doesn’t freak out. As far as run temps, the design called for incandescent bulbs then in theory the temps are accounted for, and usually are.
So, it’s down to cool factor.
98G
Former SSG
4,246
Not all LED's are multi-volt , 24v on a 12v they won't last long.
Apparently results vary. This is the first time I've heard of one blowing almost immediately.
I've used 12v LED tow lights plugged one pin at a time into the 12pin 24v trailer connection without issue.
Skrilex, FWIW I agree with your assessment.
1,807
I had a bunch of little boards with 3528 LEDs. They were super for a minute then ceased to function. I find LEDs very useful. Maybe not so much as headlights but they're virtually limitless when it comes to compartments lights. Shoot, I even have them in my trailer. It has a tiny battery and tinier solar panel. The trailer has been sitting 2 year but still has functioning lights.
dhaumann69166
77
Hyannis, Nebraska
LED’s have a voltage operating range from 4v to 30v when made for automotive use. There are some rare cases when they are 12v specific and the seller should be able to tell you if they are. I have a set of LED headlights that I got for $90 on Amazon. They already have the correct 3 prong plug on them and fit perfect. Try to avoid the ones with fancy bezel around the outside because they might not fit under the housing. LED’s are great in my opinion because the little amount of juice they take and they hold up to abuse way better than filament bulbs. Oh yea and they are blinding bright!!!
I have heard of people having issues with the tail light/turn signals when they switch to LED but I think it is an easy fix.
1,807
Now for some useless info regarding the "evil" side effect of the much brighter and much more efficient LEDs. Light pollution. Studies are showing that because their lifespan and miniscule operating costs, more folks are "Leaving the Lights On". Can't make this stuff up.
98G
Former SSG
4,246
And as a result the astronomy crowd hates them and wants laws passed to restrict them...
Skrilex
Banned
356
Portland Oregon
Ever looked down from a plane at night and seen the way certain municipalities shield their street lamps from the sky? This seems like a good code to enact. Simply putting efficient reflectors on the lamps helps a lot. However now in my neighborhood I’ve noticed all the street lamps are suddenly led. Led is naturally directional as the emit from a board. So, this will help light pollution over time.
In regard to durability, I was following a 120$k all electric Tesla the other night and it had broken leds in its brake lights. So, they are not necessarily more break resistant than incans, and when they need replacing they can be a whole bunch less convenient.
I do think they look cool and I’ve swapped all my trailers to led but I generally resist going nuts on cars because the instance of problems with either the bulbs or the vehicles after install is far too great.
Oh and I’m also the guy who if your blue hid obnoxious headlights hurt my eyes, I wait until you’re about 25’ from me and I pull brights. I wish cops would ticket people for those blue lights, I think they are a major hazard, but that’s digressing.
98G
Former SSG
4,246
Oh and I’m also the guy who if your blue hid obnoxious headlights hurt my eyes, I wait until you’re about 25’ from me and I pull brights. g.[/QUOTE]
Interesting. Is this operating on the principle that two blinded drivers is safer than one?
