colelkhunter
- 2
- 0
- Little belt mountains, Montana
So after replacing the thermostat on the 931's NHC 250 and having zero results, the problem has been the gauge or sending unit all along. Temps read with a laser thermometer have not exceeded 150 degrees on several locations on the engine and radiator. After searching here and reading up on the topic, it seems this is a common problem. I have also seen aftermarket gauges installed on builds and engine swaps, but not a topic discussing it. I was also not able to find anything related to this in the Tm's Those of you who have done it, what have you had success with? Was it a PITA? I am planning an autometer temp,trans temp.EGT and oil pressure. I plan to drive the truck on camping trips and these are the most important vitals that I want an accurate reading on. I plan to use mechanical gauges so no worries with the 24v except with the EGT i think.
