Air Brake Problems M923A2
Greenwood1
Doniphan Mo.
I am sure this has been covered before but for the life of me I can not find my specific problem.
This is a intermittent problem I have been having since I got the truck. From time to time the when I take off the parking break the brakes on two of the wheels will remain locked. I have had to rock it back in forth and go through the process of putting in in N and setting the brake again and then release it again and it will some times release. The more I drive it the less of a problem that has become. I am also having the problem of all four of the back brakes not fully releasing and dragging a little. It is not enough of a drag to notice when you are at slow speeds but when you try to accelerate it is very noticeable. I went just a short distance and the hubs were very hot. One of my friends that used to work on similar trucks suggested opening the valve at the rear of the truck where you are supposed to hook up the air lines for a trailer. When we tired that air rushed out and the brakes released. Any suggestions would be appreciated.
1,178
Are your brakes modified? Why is this posted in this forum?
Andyrv6av8r
457
Spartanburg,SC
Make sure that the vent on the right front glad hand cover is open and working. Otherwise your brakes can't bleed off air.
461
Sandyston, NJ
Have the brakes been serviced and all moving marts lubed. Sounds to me like lack of lubrication from the truck sitting and corosion building up on parts that are suppose to move.
oboyjohn
120
Quebec , Canada
I agree with MidnightDuramax. Quite often, up here in Canada, the S cam bushings and rollers will sieze up because of corrosion from salt used on the roads. It might be time to pull the drums and service your brakes.
