panzerjunky
- 0
- 0
- san diego ca
When I stopped mid way home and checked the brake drums for heat and found one side a little warm I turned off the main valves on both service and emergency popped off the gladhands to relieve pressure. and pit them back on with the main valves closed just so they looked hooked up.
My theory was to go a few more miles to see if the drums cooled down.
anyway the truck would not move.
so do I have to have air at all times to release the brakes so the trailer will move or do I just drain the trailer mounted air tank?
If someone has the time could you explain how the system works.
Thanks Jerry
Thanks Jerry
