Air Buzzer
hammerdown
UK
Where can i find the Air Warning Buzzer around the dash
as someone has disconected mine????????GGrrrr,:twisted::twisted:,Thats all very well not listining to that buzzing on start up. But it
would'nt be funny if the pressure dropped while driving:driver: and you didnt
no about it as there is only a certain amount of times you can keep your
eye on the air guage.:(:(
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
It's about 6-8" square box on the inside firewall slightly off center towards the passenger side. It has one wire going to it IIRC.
cranetruck
75
Meadows of Dan, Virginia
As a warning device, the light is a bit iffy in MHO, sunlight will easily drown it (like the turn signal indicator by the steering wheel, which is impossible to see when the sun hits it).
My solution is to use a turn signal flasher unit to run the buzzer. The intermittent buzzer sound is much easier on the ears.
The turn signals also run the buzzer as shown in several earlier posts...
hndrsonj
363
Cheyenne, WY
Very good idea Bjorn. I would definately not go with just the light (I have both too).
