Air cleaner
CES 3245th
Boston Ma
Ithought I would throw this question out, aswell looking for pros or cons on this product. Has anybody used this AIRCLEANER CUSTOM KIT from Those Military Guys website?
[/h]
Brutacus
198
Marion, AR.
I have. It seems to let my engine breath better. I have a nhc 250 in my M818. The engine idles smoother, and has slightly better throttle response. I don't know if there is more power or not, but overall the engine breathes better with the smaller diameter filter.
Brutacus
198
Marion, AR.
Yeah, I got mine from those military guys. I waited until they had a free shipping and 10 percent off sale. They do stuff like that from time to time.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
Since you have a nhc250 if you want more power it is best to fix an intake on the inner fender well and use the black out light area for forced air flow. I have an 8in grated opening that flows 40,000cfm of air at 55mph. With a high flow filter rated for 1100cfm she gets more air than she wants which really boosts your power. Also allows you to bump the fuel up
Sent from my SM-G935P using Tapatalk
CES 3245th
Boston Ma
So let me ask you this
, if you had to buy it again would you do it? And did it make a difference and worth the money that it cost?
thanks once again
Brutacus
198
Marion, AR.
I don't think i have the room on my truck to do what you did to yours Wes. Not a lot of room under the hood of my m818 compared to your M923A0. I still like your setup, and have considered mounting another air filter drum on my passenger side fender, tying it in to the intake from the driver side to form a dual 5 inch intake system with some ram air scoops on top of my drums. And Yes CES 3245th, If I where to do that, I would get another one of the filter kits from those military guys. I think it's a worth while modification, which is cheap, and easy to install.
simp5782
9,322
Mason, TN
The OP has a 923A1. The 809 trucks get enough air where they are at.
big block 88
17
Topeka/Kansas
I didnt buy the kit. I judt cut back the inner flange that surrounds the filter. If you look up inside the air box you will see there is a shield surrounding the air filter and blocking the direct air flow path of your snorkel i cut that shield back anf noticed better response. So i wouldnt spend that kind of money on the tmg kit....
