Air Comp. Pulley
Barneyszoo
12
Riverside, CA>
I'm looking for an air comp. pulley for an M35a2. The threads that are used to set the belt tension are bad and they won't let the belt get tight enough.
saddamsnightmare
80
Abilene, Texas
January 3rd, 2010.
Barneyzoo:
I'm sure that the guys that Will Wagners goes to for duece parts out your way should have a take out pulley, otherwise contact Boyce, Memphis or White Owl. If you can get the pulley off the compressor shaft, any good machine shop should be able to remanufacture your old pulley for you.
Just a thought,
Good luck and Cheers,
Kyle F. McGrogan:-D
twright
Rockmart Ga. 30153
Souunds like you need a new comp. are the threads on the comp good ? you need to make sure before you try to put on a new pulley I might have a pully I will have to look.
AEC Retired Tony
Barneyszoo
12
Riverside, CA>
Thanks, the threads on the comp. shaft are good, its the threads on the two halfs of the pully itself. I could put it on a leath but its more trouble than its worth, I'll just replace the whole pulley ass.
