Air compressor filter
lawdog1623
Texas
Well guys the last few days have been adventure. Im in the process of painting the engine in my m35a2. I removed the compressor to balst in in the cabinet. I took every precaution to ensure the media didnt get inside the compressor. Much to my surprise there was more inside the compressor than was in the cabinet hopper after i got done. I was so ticked. It was nearly locked up. I took it apart andput it in the parts washer. After several hours it was sparkling clean and smooth as silk. I got the piston back in, checked to ensure that it lost no fluids around the rings and reassembled it. I had to custom make all new gaskets from felpro gasket sheets. I then got to looking at the "filter" and i was horrified. There was no way this thing filtered anything. I looked around and found no filters acailable. I was hoping to find a replacement filter at napa or somewhere else. Do any of you know a part number or have ideas?
John S-B
1,048
Ostrander, Ohio
I'd just get some of the finer abrasive pads (like they use for scrubbing teflon pans) and cut out pieces to fit. that should at least work temporarily. Another alternative is to go to a small engine shop and see if they have any air filters that you can trim to size.
saddamsnightmare
80
Abilene, Texas
August 23rd, 2012.
How about connecting it to the Engine Air Filter can through the engine intake connection? At least you'd be getting air cleaned by the filter element. (I mean connect to the actual engine air intake hose, not the normal air compressor connection on the can, as that air is only filtered by the mushroom), but if you have the 90* elbow and stack as in a fording set up, there would be less dirt in the air compressor intake air....:?:
lawdog1623
Texas
well, this seems to be the easiest option. I want to make sure that it cleans it a little better than it was before. Ive been looking back at older threads and it seems that this is the easiest option. I just cant bring myself to place that pathetic excuse for a filter back in the compressor. That thing just doesnt seem to me to be able to filter anything.
