drlogistics
- 0
- 16
- Lapeer, MI
Anybody ever have problems with their air compressor governor not working properly? At first mine would not cut off the compressor so it would just keep building air until the bleeder on the tank would let off the pressure. I've lived with it for a while but the bleeder on the tank is extremely loud and annoying. Plus it doesn't bleed until it reaches 150 psi. So I took the governor off and took it apart. Everything seems to be in working order. I also checked the 'trigger to stop' and another clearance measurement per the manual. After putting it back together I am half way there. The compressor will cut out around 100 psi now. But it will not cut back in when I bleed air out of the system. The only way I can make cut back in is to manually press the trigger down. Kind of hard to do while driving. Any advice would be appreciated. Thank you.
