- 821
- 1,651
- 93
- Wauchula, FL
Just noticed trace amounts of oil venting off the air dryer exhaust port. I have upgraded the drier to the newer style with the replaceable cartridge. Is this normal or am I seeing a potential problem?
It should be a factor of how often you use the brakes. If you start the truck, it should fill and purge once, the not again until you use the brakes enough to drop the wet tank pressure low enough to engage the compressor(thats where it senses pressure).Not sure where the air feed is from. It’s all still original 2003 3126 m1078. All the lines are clear and no kinks. I’ll pay attention to how often it purges. How often is normal?
