helomech
- 0
- 0
- East Texas
My truck started leaking lots of air from the air dryer (I think that is what it is called). It is under the bed just in front of the first rear axle. There is a 3/8ths bolt inside of it that if I tighten it, it stops leaking. The leak is bad enough that my truck will not build air pressure at all unless I tighten the bolt. Problem is within a few miles it is loose and loosing air pressure again. Has anyone run across this. I am digging through the manual looking for something, but if anyone has had this issue please let me know what you found.
