Air fittings at the 3 valves in the driver wheel well ?
1951M1078
185
Glendale,AZ
So I got my missing valve ( front left ). # are 3/8" hose and one is 1/2" hose. The valve assemble was missing the hose fittings caps,ferrell and crunch tubes. So I went to my Weather-Head stuff. The 1/2" is fine but the 3/8" have a different thread than my Weather-head ?
Can anybody tell from the markings ?
Thanks, Randy
1951M1078
185
Glendale,AZ
Going to Hose Power Wednesday to see what I can find. To tell you the truth I didn't know their could be different kinds ?
If you get a chance that would be great. Thanks, Will.
1951M1078
185
Glendale,AZ
Just got the word. If its a DOT splice and it does not leak I'm good to go. Cool.
So the plan is to remove the 3/8 " lines from the chassis. Install new lines on the valve and mount it back where it belongs. then I will make the splice to the chassis lines to the new lines from the mounted valve. Simple ! NOT !
