Air Horn fix....
dm22630
42
Front Royal, VA 22630
My air horn sounded a little weird (I thought).....but since I never had an air horn before, I thought that it was normal. It was a loud wheezing sound....
Then it quit working. It just sounded like someone trying to whistle.....sort of like a lot of air w/no pitch.
SO, I decided to investigate & upon closer inspection, I saw that not one....but both air horns had unscrewed themselves. I hand tightened them up and pressed the horn button and deafened my neighbors.
WOW are they loud! It sounds like a train horn now. :mrgreen: :mrgreen:
So, if your air horns are not a loud as you would like....make sure they are screwed on tight.....it REEEEEEALLY made a big difference w/mine!
Barrman
1,762
Giddings, Texas
You can also adjust the little screw in the back. Speaking of train horns. Colton and I were driving the M35 yesterday and got to the train tracks about the same time as a train. He was blowing his horn and I blew mine back at him. He actually jumped. Then he smiled and waved. Colton thought it was real neat.
wdbtchr
St. Louis, MO
I always thought the air horn on my M51A2 sounded kinda nasal, rather disappoinging, I guess I'll have to check it. Right now it is disconnected at the steering column because the horn blows at odd times and I've never been able to figure out why. Sometimes when you turn the wheel, push on the wheel or hit a bump it will blow. I've been looking for one of those horn buttons the mount on the steering column to use.
m16ty
217
Dickson,TN
I'd say you more than likely have a bare spot in the wire that runs through the steering column and as you turn the wheel or hit a bump it shorts out aginst the column or it could be in the button.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Horn won't blow on my M108 unless the engine's running. Something about the vibration? Not worried about it, too many other things to fix.
BEASTMASTER
142
Burgaw, N.C.
the horn blows because the wire going up the steering column is the ground, it must have a bare spot and when it grounds out blows the horn
