Air hose part number
dirtyfingernails
Gainesville, FL
Noticed that the flexible high pressure line that runs from the pressure gauge (on the dash) to the fireway distribution block is hissing. Anybody have a NAPA equivalent number or is this an item for one the MV vendors? Thanks much.
Steve
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Make sure it is the hose.
The sensor on the wall, that it and the electrical connections hook to, has a small vent hole.
I removed & swapped this hose on mine and found the hiss was from the valve/sensor as it bleeds down.
Tony
m-35tom
222
eldersburg maryland
that is the air pressure switch. sometimes the little screw inside comes loose. if that is it just take it apart and tighten screw and the leak will stop.
sprucemt
14
Warrensburg NY
The hose has an o-ring in the swivel joint also that degrades. The hose is posted on my website at the M35 page. No, I do not have any currently.
