Air Hydraulic Cylinder
steelandcanvas
87
Southwestern Idaho
Looking for the "airtube" that goes on the air hydraulic cylinder. Mine has got a bad kink in it and it should probably be replaced. Is this something I can make myself, or is it available?
While I'm at, should I rebuild the cylinder with a kit?
acetomatoco
9
Never mess with an AirPak which is working correctly other than to put the OHT in it every six months... You should be able to make a new air tube... just splice in a new section with good compression fittings...
