Air Hydraulic cylinder
Ok this is not in the TM but i found this in Military Vehicles issue 91 2000 it says you need to put one ounce of OHT oil in it (MIL-H-6083) this to permit lubrication of the air piston cylinder the oht is a petroleum base hydraulic oil And the oil should have no additives in it keep it from attacking the rubber seals It says this is the problem with the air pack not working
jwaller
19
Columbia, SC
ya this has been discussed. most use a tablespoon or so of air tool oil. thats what I've been using for the last few yrs.
BEASTMASTER
142
Burgaw, N.C.
yep, thats what we are saying . the air pac . you take out the little plug , squirt in a little air tool oil and put the plug back in. been doing it for 5 yrs, now and no problems. knock on wood. i do it three times a year.
