MikeON
- 12
- 18
- Lucinda PA
I put Air-o-matic steering on my deuce about 3 years ago.
Yesterday, while turning right onto a side road, it would barely turn right and I had to go way into the opposite berm of the side road to make the turn. Fortunately, there was no oncoming traffic.
In the driveway, I saw that the front wheels would only steer just a little right of center. The picture shows what happened. The tie rod bracket slipped to the left and upward. It would hit the spring, and the air cylinder was probably also bottoming out internally, limiting the travel in a right turn. Some of the bolts were loose. I am 100% certain that the bolts were tightened to the correct torque when installed.
Apparently, my tie rod had an extra thick coating of CARC, which broke loose from the steel and allowed the bracket to slip. The correct location for the bracket is the bare spot on the tie rod pointed to by the arrow. It should also be just slightly above horizonal according to the installation instruction, not way high as shown.
Everything is back in position and it steers fine again. I suggest that anyone installing this kit to strip the CARC off the tie rod. I'm also planning to recheck the torque on the bolts regularly.
