Air outlet for compressor
Boatcarpenter
17
Marlborough, NH
Do you guys that don't have fording kits have the outlet for the air compressor on the backside of the air filter housing plugged. I'm wondering if that would let enough air in so that the 2x4 trick over the main inlet wouldn't work to stop a runaway engine.
cranetruck
75
Meadows of Dan, Virginia
Good point BC.
If you want to keep a permanent connection for the compressor, you should be able to, I have had the compressor air inlet hooked up for a couple of years and thousands of miles without a problem.
patch
Buxton Maine
Here's another good reason to put the hose on your air filter housing- Found a mouse nest in mine when I went to start the truck after a few months. Looked like they used part of the passenger seat for the nest. Mushroom cap was on tight... Damn those rodents can get in the smallest places.
moreorles2
Freedom, NH
BC- I was able to locate the entire TM 9-2330-209-20 series in 7 PDF files that you are looking for in the Classifieds. They are too big to send via email. PM me your mailing address and I'll burn a CD and send if via snailmail if you still want them. Thanks again for your input. :roll: :roll:
moreorles2
Freedom, NH
BJorn- sorry to be a pest- I was under the impression that the 2nd external hose on my deuce was for the compressor. After looking again on the TM suggested by Boatcarpenter- I realize that it is the crank breather hose- not the compressor hose that is external to the cowl along with the air intake. The previous owner ran it out the passenger air vent. However- I do not believe that this is kosher. Anyone have the fording kit installation instructions with a template for where a second hole has to be drilled in the side panel? Thanks all....
wallew
M,
Did you mean TM 9-2320-209-20 series? Or is there manual I may be missing?
thx.
Bjorn, WHY DO I SUSPECT the smile on your face during that crossing was huge? Great pix, whoever took it!
jim
1,806
Including the HR there are 17 manuals in the most recent 209 series. The 65 dates series has 5. I just updated the 209-10 stuff to include 209-10-1 thru 209-10-4 and put the HR manual in too. I didn't realize that all the other 209 manuals are not on this site. I'll go ahead and start adding them when I can to complete the series. Magnus580 has one of my old 1965 209-10 manuals that he is duping to PDF format. It has the M44A1 trucks as well as the gassers. It's going to take me a while but the good news is that I have them all! BC, are you looking for anything specific on manuals?
wallew
Kenneth,
On the CD that I got from Robert (rdixiemiller) there are 21 209 manuals including the HR. Some of them are multi sectional, so maybe that's the difference.
This CD has been INVALUABLE to me. Kudos go to Robert (rdixiemiller) for doing this. And if you own a deuce AND don't have this CD, you are missing information, I'd bet money.
jim
cranetruck
75
Don't forget your little PS Magazines, they were given "TB" status 15-20 years ago.
"PS" stands for Post Script in the true sense of the word and adds/corrects info that you find in the TM's.
I got a CD from Military Media Productions for about $20 a few years back and it contains 28 manuals. There must be many more out there on the deuce since I also have a few not listed on that CD.
Some are FM's, though.
Jim: My son took that picture, its a frame from the video.
1,806
I didn't count the LO, trnasportability guidance, and a few TBs for things such as the center mount troop seats and the like.
