The solution to the problem was posted with in the 30 minutes of the OP's post.
He doesn't have hours to search, yet has hours to change parts randomly.
2 days have past and his problem is not fixed yet, because he changed the least expensive part.
He changed a cheap part instead of reading for free.
It takes less than 20 minutes to read the table of context for every single TM for the 939 series.
A general search for protection valve will yield the results needed to find the picture of it and the part number . A child could probably find it with a little common sense, in about 20 minutes, from the search results.
Sometimes the best help, is not doing someone elses work. At this point, the op will still be helpless when he has another simple issue. He needs to stop fearing the TMs, and get comfortable with them. They contain much more than we can share in the forums.
