nickd
- 36
- 28
- Newport, Delaware
The part number is Gabriel of Canada #615116
My floor has oil on it, I power-washed it 400 miles ago. It is pretty easy to compare one truck from the other(obviously). I had the seat(with bad shock) set where it supports me well but, when I hit a mild bump it will still bottom out(ouch). The other truck with a good shock, will comfortably float me over the same size bump. An easy way to check would be to unbolt the bottom shock bolt and compress and extend it and see if there is an even resistance as it is compressed (my bad one will just go in and out with no resistance at all).How do you test if the shock is bad or not? I have only the one truck, so can't compare.
Thanks Jason.Just an update to this thread. The parts unlimited is running about $40 and the KIMPEX 298754 is running about $25 online.
