air shift problem on m35
dozer113
jackson/mi.
On my duece when I activate the air shift the air bleeds pass the piston and vents out the top of my transfer case. Are there seals or o rings on the piston that would allow the air to pass bye? Any suggestions as to the cause of this problem?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
You have been warned, if it is that air valve that engauges the front axle, they SUCK to work on, no room AT ALL!
dozer113
jackson/mi.
Yeah I worked on it a little and there is very little room. I pulled the top cover plate off the piston to make sure it was not stuck, everything looked fine and the piston did move, but your right, very tight quarters...
Bill W
44
Brooks,Ga
The piston on my airshift was put in backwards but the seal still held air barely
Heres a pic for reference ( remember the pic show a backward install thicker part of piston should face out). There is a guy on e-bay selling a kit for these ( $37.50 ) if you can't find just the seal
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
If you grind flats on the outside of a socket, you can use the socket and a wrench to remove the nut that holds the piston on. Then the piston and cylinder can be removed.
m-35tom
221
eldersburg maryland
the cylinders on my air locker axles did the same thing after being in storage for years. i put some oil in the feed line and it fixed itself. almost the same arrangement, so i would certainly try that first.
tom
