davemccoull
- 2
- 8
- Nelson Lancs U.K.
Having got my air shift transfer case fitted, I came to couple the flexible air feed to the backof the switch, and noticed the fitting in the switch is 1/8 B.S.P. taper with a flat end. On the flexi tube there's a swivel nut 1/8 B.S.P. with a female cone seat. I don't see how this can seal, looks to me like there should be male cone on switch fitting. The fittings on the air pressure gauge are just the same. (the fittings don't seem to be leaking, I've yet to test with soapy water)
Would appreciate your views,
