Airlift bumper bracket
MOOSERABBIT
Morgantown, WV
I have gathered most of the parts to put an airlift bumper on the m998, however I am unable to locate the inner brackets. My question is will the outer ones work. I've tried the search and cannot find anything.
Gary
Stonewall
Peoria, IL
There are essentially three different supports. Inner Brackets, Outer Brackets, and Outer Braces. A popular auction site has several listings for the inner brackets and outer braces. The outer brackets are a bit harder to come by, and they come as left & rights. You do need the Outer brackets because the body of the hmmwv mounts to those. You could get away without using the inner brackets, but you do need the outer brackets.
juanprado
2,885
Metairie/La (N'awlins)
Make sure the bumper matches the frame bracket. If you have the a2 bumper with hole for teardrop shackle , you will need the bracket that has that hole also drilled. Don't ask me how I know.... or you can use the one without hole and drill your own.
MOOSERABBIT
Morgantown, WV
I have found the brackets, but I see the interior braces, left and right, they have a different part number than the outside braces, those are the ones I cannot find. Are the outside braces a substitute?
