jerseyjeep2003
- 1
- 0
- Gloucester City NJ
OK, so I tore down my air pack for rebuild and found the air side to be in decent shape, had some brake fluid in it, but no rust whatsoever. Now on the other hand, the hydraulic side has a fair amount of pitting. Starting at the end with the brake light switch extending about 2 inches in, the bottom (like it was sitting for a while with water laying on the down side of the cylinder) has a section of pits that look to be maybe .010 deep. My question is, will honing be ok? I know the rubber cups are pretty forgiving and will take up a fair amount of the cylinder being oversized. Or maybe send it out and have it bronze sleeved? I really looks as if the pits are past the travel of the piston (with properly adjusted brakes). I would replace the whole unit, but you don't know what you get with used and the new ones are way too pricey. I THINK I could get it sleeved for less than $100. Just have to find a shop that does that type of work.
Thoughts?
Thoughts?
