All fluid Levels
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Lubrication Order. I don't know for sure but, 5 gal oil, 5 gal coolant, and for trans+Tcase+axles close to 10gal gear oil. I'm sure someone will give you exact measurements soon, but this is close.
gimpyrobb
27,785
749
Cincy Ohio
Lets see if I got this right,
Crancase 22qts
Transmission(with pto) 8.5 pts
Power divider(Tcase?) 3.5 qts
Differential 6qts each
Bfs (brake fluid silicone) I'd say bring a gallon, couldn't find spec.
Radiator I couldn't find
This is just what I could find, that does not mean I am correct. Your milage may vary.
cranetruck
75
Meadows of Dan, Virginia
The radiator is about 5 gallons and the engine about 3, for a total of about 8 gallons. When filling the radiator, open one of the pipe plugs near the thermostat on the engine side to vent air.
I use distilled water, glycol and 2 pints of additive... Do a search on this particular subject if you have any further questions, lots of hits....
FreightTrain
Banned
2,730
13
Gadsden,Al
All gear boxes,GL-1 Rated 90W oil.Do not use GL5 unless it is yellow metal safe.Napa has GL-1 and even cost a little less than GL5.
Engine 15W40 oil
Brakes Dot 5 silly-cone(Do not buy Dot 5.1 not the same)
Coolant.6-8 gallons of 50/50 mix water coolant.Make sure the coolant is Mack rated.Do not use "Car" stuff.Buy the big rig coolant.Plus Test strips and a couple bottles of SCA/DCA Anti-cavitation junk.
FreightTrain
Banned
2,730
13
Gadsden,Al
oh yea,You will need 2-5 gallon buckets of gear oil.....5.5gallons of 15W40,Several bottles(Think I used 4 or 5 CHA CHING!Ouch) of brake fluid(if your gonna flush it),4 gallon jugs of big rig coolant,4 gallons of distilled water and 2 bottles of DCA/SCA additive.
jasonjc
287
Gravette Ar.
Diesel coolant has/needs diferant additive than a gas eng coolant. If you do a search it is cover real well by cranetruck and how to test the additives , a must read.
Get your self a hand pump for the 5 gal buckets of grear lube. They are like $20 and well woth it. Almost a must have. You can do it with out but you will not like it.
FreightTrain
Banned
2,730
13
Gadsden,Al
Diesels cavitate due to high compression where the toy engines don't.The Cylinder walls actually bow out into the coolant jacket and snap back to normal size.when this happens a vaccumn bubble forms on teh outside and colapses.The sudden pressure change creates a shock wave and the coolant jackhammers it's way though the wall over time.Old IHC/Ford 7.3L IDI engines were BAD about this.most usually died at 100K but some have passed on after 20-30K and some less.
OD_Coyote
58
North Bend, WA
FWIW - I have read some bad things about the new CJ-4 rated low emissions diesel motor oil related excessive wear on engines with flat tappets, so you may want to use an oil additive like ZDDP+, SFR 100 or D-SOL or see if you can find the coveted CI-4 rated oil.
