All my lights stopped working except the light in the gauge area.
4x4nutz
117
Mico, Texas
All my lights stopped working except the light in the gauge area. Before I replace my switch panel, anything else it may be?
Milcommoguy
2,261
Rosamond, CA
Lots going on in the lighting switch. Having panel lights says you have battery power to it. Be sure connector is all the way in and hand tight. Did it ever work? IF SO, make sure there are no shorts on other lamp circuits IE: headlights, markers stop / turn. Here's another test. Does the horn honk? (did it ever?) It goes thru it too. NO shorts, change it. Watch out for knock off parts on this item.
OEM or do it again, CAMO
INSIDE VIEW Lots to go wrong and could have burnt up contacts, If you can open it.
