Allison 3000 Transmission Pan Jacking Bolts
Delirium
Raleigh, North Carolina
Hey y'all, working on getting at the guts of the MD3070PT in my M1078A1 for a thorough run-through and casual glitter hunting. The TMs and TS2973EN have been great so far, but there's one thing hanging me up as of this past weekend: The jacking bolt threads on the transmission pan. They are mentioned in 34-2 on page 7-71 and nowhere else, not even in Allison's documentation. Anyone know what size bolt is needed for those? I've gone through my bucket-o-bolts and can't seem to find anything that works, and I'd like to avoid getting physical with the pan and marring the separator plate or worse.
GeneralDisorder
6,072
Portland, OR
Typically in such cases they are designed to use the control valve body assembly mounting bolts (once removed) as the jacking bolts. I don't know that for a fact but that is convention in the industry so I HIGHLY suspect that is the case here.
That's not a pan. It's a control valve body assembly that happens to double as a sump. Be prepared as it is VERY heavy.
