TTdogs
- 0
- 1
- Hartline, Washington
I am having an issue with my M923A2. When shifting from Neutral into Drive or Reverse the converter is locked up some of the time. Reverse is worse especially in low range. If it doesn't kill the engine, it will then start working fine until you stop and sit for a bit in Neutral.
This started after we repaired the Hi/Lo lock out switch wire and did some work on the bed. It had not done this prior to that. I changed the fluid to Synthetic Dexron 3 but, I have not changed the internal or external filters since I did not have them.
I use this truck every day and the nearest Allison repair shop is 100mi. away. I am hoping someone has some ideas of some things to look at.
