allison converter lockout malifuction
Suprman
680
Stratford/Connecticut
Drain the fluid and drop the pan and look at the filter see if there is metal shavings and how the fluid looks and go from there. Other than that take it to an Allison dealer and see what they say.
av8or
fort denaud, florida
No metal, new fluid & new filter, twice on oil and external filter no joy.
quickfarms
24
Orange Junction, CA
Thanks, That's a last resort. just hoping for a magic fix.
Take it to an Allison service center and let them diagnose it.
There is a bunch of adjustments that can affect the lock up.
Does it stay locked all the time or is this just an issue in certain gears, rpm or speed.
When you serviced it did you drop the pan and replace the internal filter. If you replaced the internal filter did you make sure the pickup tube was the correct length?
av8or
It stays locked all the time and has sense I got it from Warner Robins (was a supply truck. Yes pick up tube is OK
