Ronmar
- 6,984
- 113
- Port angeles wa
After some analysis and math, I decided to try this pump out and think it will work well for my needs… FYI…
Is the handle removable?After some analysis and math, I decided to try this pump out and think it will work well for my needs… FYI…
Yes, it is. When I land the pump in it’s final location, I may make the lever just a hair longer with a T handle which will reduce the force slightly and make it a little more ergonomic to operate.Is the handle removable?
Looks like a great pump!
could this be used for tire by going thru a home brewed manifold valve arrangement.... and or the Military manifold? IMHO better would be home brewed so can get parts more local when a rebuild is needed . Guessing similar restrictor valve as you have proposed could be used to keep tire from dropping too fast as you suggest for keeping cab from dropping to fast too...... though it looks like your valve in the video works fine for that.... maybe put a spring to hook to valve arm. Thus when putting it in lower position spring tugs it back just enough to not let it open all the way.... thus restricting flow.After some analysis and math, I decided to try this pump out and think it will work well for my needs… FYI…
Yes, you could, but I would want a longer lever as my tire needs like 2200PSI during lift. I think my cab went just over 1400PSI. 50% increase in pressure = 50% increase in force required, or closing in on 60# at the end of that lever. A longer lever would make this maneagable.could this be used for tire by going thru a home brewed manifold valve arrangement.... and or the Military manifold? IMHO better would be home brewed so can get parts more local when a rebuild is needed . Guessing similar restrictor valve as you have proposed could be used to keep tire from dropping too fast as you suggest for keeping cab from dropping to fast too...... though it looks like your valve in the video works fine for that.... maybe put a spring to hook to valve arm. Thus when putting it in lower position spring tugs it back just enough to not let it open all the way.... thus restricting flow.
Ronmar, was it you I met in the parking lot of the courthouse the other day when I was trying to register my 1078?After some analysis and math, I decided to try this pump out and think it will work well for my needs… FYI…
Yes, I was parked at the east end close to Vern Burton. There was a guy that came over when I was leaving that said he had a M1079 and a M1083. I either didnt get his name or forgot it. My mind was focused on being pissed at the auditor's office. It is a small-ish area, maybe I will see you around.I don't think so, i do work for the county, but havnt met anyone in the parking lot…
did you have your truck with you?
@RonmarI was asked about a drawing for using this pump for both cab and tire lift. This drawing, and the parts described assume re-using the JIC4 hoses that are already on the truck. If you change hose end type, you will need to change adapters accordingly. The hand pump and the dual selector valve shown both use 3/8” Female NPT ports and the WFC flow control valve uses 1/4” NPT. All the parts except the 3/8“ port dual selector can be had at surplus center dot com. The dual selector is on amazon or Bailey hydraulics. The important thing to note is that the line off the pump that has the flow control valve attached needs to feed the lift side of both cylinders, so it can restrict/control the flow coming back out of the cylinders as they lower the heavy weight. This is the base end of the cab cylinder, but the rod end port on the tire lift cylinder… The tire lift also requires 25% more pressure, so will require 25% more lever force. A longer lever may be in order…
So if I am counting right:
7EA 3/8” Male NPT to JIC4 male adapters.
1EA 1/4” Male NPT to JIC4 male adapter.
1EA 3/8“ NPT Male to 1/4” NPT Male elbow.
Wolverine 1.5 CU/IN Dual acting hand pump.
Wolverine 60 CU/IN hand pump reservoir/mount.
Wolverine WFC-400 flow control valve.
Metro 280379 dual selector valve(amazon Or Baileys).
little bit of attitude(google it)
Thanks for the additional information Ronmar. Yes, unfortunately, both pumps are having issues. I can actually get the cab up to the tipping point if I pump furiously for about a 1,000 pumps and that is no exaggeration either, but I can't get it any further than that. It literally took me about 1,000 pumps and only works then if you pump really fast. When using the air/hydraulics, I do see the mist coming from the hydraulic pump, so I'm pretty sure it needs a rebuild, but that doesn't explain why I can't get the hand pump to work. I am not familiar enough with it just yet to understand how the hand pump works, so maybe my issue is the control valve? What should I look for in regards to the control valve?Well it is about 4X too big, which means it needs 4X the cable size and will pull 4X the current needed to actually do the job, while sending 3/4 of the fluid thru the safety relief valve. The 0.8 GPM is I believe a typo based on the KW rating and the port size, and farther down in the description it says 2GPM. You want under .5 GPM/-4 port size(not easy to find, I have looked)… My inability to find an appropriately sized electric(and the simplicity) was why I went with the manual only.
The flow thru the system is restricted by orifices in the control valve to not activate the safety devices built into the cylinders(catches the cab or tire if you blow a hose). You can use a larger pump, but it wastes most of that flow/power. A 12V@2GPM pump also pulls upwards of 250A. Thats like cranking nearly 2 engines(my starter pulls 150A) at the same time for a 30 second cab liftIf you use an oversized pump be sure the safety relief is set appropriately(23-2500) because without enough system flow to absorb the pump output, it will immediately go to relief pressure(I think that one you linked to is 3200PSI which might be more than this system can handle)…
Both your pumps are doing the same thing? The point of 2 pumps is to avoid this sort of thingFirst off is the hand pump reservoir full? There is an allen head plug on top to add fluid to it’s reservoir. You could have an issue in the control valve that is re-circulating fluid instead of sending it to the cab cylinder, and both your pumps are Actually OK. You can play musical hoses and connect one of the suspension compression hoses directly to the hand pump output port. With the lock pins in place on the cylinders it doesn't matter which hose you choose, and the output port will be basically sealed. Now try and pump the handle. if it pumps with nothing moving and no fluid spraying, the pump is the problem. If it is solid as a rock, the pump is OK and the control valve is probably the issue…
Good luck.
