ALternator Leece-Neville 3002AVC
Christian BLOCK
SOMME-LEUZE, Belgium
Hello,
I have a Leece-Neville 3002 AC alternator that doesn't charge.
According to TM, everything is fine.
I have the battery voltage on the small cable (56 8th) when the ignition is switched on.
I have the battery voltage on the large cable (5).
When you run the engine and switch on the headlights, the voltage on cable (5) remains the battery voltage.
What's more, the voltmeter on the dashboard doesn't move, remaining on battery voltage.
Does anyone have any idea how to fix it and where to find spare parts?
Thanks in advance for your help,
Christian
lpcoating
856
Mansfield, PA
Hello Christian. While I'm sure there are people on SS that can help you with this, the 151 activity on here is pretty light. If you don't get an answer, I'd recommend checking out the G503 or G838 sites for help.
Guy
