alternator lights
jdcucv
Wisconsin Rapids, WI
On my 86 cucv the gen lights stay on. Number 2 is always on and number 1 comes on when any thing is one such as head lights, fan motor, turn signals any ideas thanks
HAWKMAN
N.E. P.A.
Re: RE: alternator lights
dependable said:
First check belts. if they are not worn thin and are properly tensioned, you may need new alts
You can pull your alts and take them to autoparts or auto repair that has alt testing machine and get them checked to eliminate all doubt. If you find you need to replace an alt I have a couple available from M1009.
emmado22
143
Mid Hudson Valley NY
Make SURE the testing place knows they are ISOLATED GROUND... If they ask you "whats that?" RUN AWAY FAST..... Most places dont know how to deal with the iso ground alts....
jbolty
San Diego, CA
FWIW
I just had to replace a diode set in one of my alternators (left one) and in the process of searching for information about them I found a mention of the exciter circuit somehow being wired off the heater circuit. Can't find the link now but I may have it at home.
