Alternator Question
dmc-4359
Chapin, SC
That's the way they come from the factory. Arguably, only one needs to be isolated but in order to make them identical it did not hurt to have both with isolated grounding.
mtinsman
martinsburg, wv
Ok. I bought 2 new alternators off of ebay and the ad said they were for a M1008. I got them put them on and the fuseable link that goes from the battery to the firewall fried. what could have happened????
Warthog
232
OKC, OK
They where either hooked up wrong or the alts do not have the isolated ground.
This was covered just last week. Do an advanced search for "alternator" in the CUCV forum. Many, many posts. Here are a few.
http://www.steelsoldiers.com/cucv/4...side-alt-connection.html?highlight=alternator
http://www.steelsoldiers.com/cucv/4...ain-isolated-ground.html?highlight=alternator
http://www.steelsoldiers.com/cucv/4...ator-wiring-diagram.html?highlight=alternator
Do you have an Ohm meter? Do you know how it works? (some people don't)
Check the ohms between the case and the ground lug. It should be an open circuit.
mtinsman
martinsburg, wv
Ok I will do that I have an Ohm meter I will check it. I researched the hook up of both alternators and I hooked them both up correctly my guess is that I bought two alternators with no isolated ground.
Warthog
232
OKC, OK
Ok I went home and did an Ohm check on the passenger side alternator and it read between 000.2 and 000.3
Was this a new/rebuilt or used alt?
The ground terminal is not isolated from the case. You have a direct short from the battery to ground. That is why the fusable link fried.
Open up the case and see if the fiber washer was installed on the inside.
Just last week a fellow member had his alternators rebuilt and the shop "forgot" to install the fiber washer in the inside ground terminal
http://www.steelsoldiers.com/cucv/49353-m1009-passenger-side-alt-connection.html
mtinsman
martinsburg, wv
The alternators are both brand new I got them off ebay the ad said they were for a M1008.
I just ordered the alternator from napa WIL 90014277 should be in tomorrow.
