Alternator tensioner pulley replacement for M1078
DiverseThinker
11
Indian Trail, NC
New to the group and this is my first post after purchasing my 1995 M1078 LMTV from a member on this site. I believe it has the 3116 engine. I had a catastrophic failure of the alternator tensioner pulleys when they came apart while the vehicle was being driven. Sounded like an explosion going off. The bracket of the tensioner is fine but I do need to replace the dual v-groove pulleys. My issue is I do not have the originals nor can I find a part number to reference in the TMs. I searched this sight, but either my search terms were not on point or this topic has not been discussed....I bet it was my search terms. Any one have the specs of the diameter of the pulleys, part numbers or have a reference to an aftermarket replacement?
coachgeo
3,407
North of Cincy OH
from the yellow spread sheet. This sheet is linked to in the thread found pinned/stuck to the top of this FMTV forum
Vendor______________________________________________________________part # ______________________Vendor _______________part #
NAPA/DAYCO38550CAT253-1864
Ronmar
7,296
Port angeles wa
When you search that P/N it shows a spring loaded tensioner for a serpentine belt, so that is not the correct part for a 3116…
DiverseThinker
11
Indian Trail, NC
Thanks coachgeo & Ronmar. I saw this spreadsheet but this part is for those engines that have a serpentine belt. I am looking for, I assume, the older version. Part number 5 in the attached diagram. It appears to be 2 v-groove pulleys. As mentioned, the bracket is OK. So all I really need is the pulleys, but I will take the full bracket to get the truck back on the road. The TM also calls this a "alternator belt take-up mount".
coachgeo
3,407
North of Cincy OH
Does this help
Ps- once you find the number do pass it on.... thanks
coachgeo
3,407
North of Cincy OH
in the TM's did you find the NSN number for it.... some of the NSN search websites will post additional part numbers you can use to track things further
DiverseThinker
11
Indian Trail, NC
what about this one?
https://parts.cat.com/en/catcorp/100-6267 though in this one it calls it an Idler
Coachgeo, You are a machine finding all these possibilities. This is the plate and Pulley for the water pump. The problem with many of these parts, on this site and others, is they do not have specifications. The only specific I know is the shaft diameter the pulleys need to slide on to is 1.375". I am assuming the diameter of the pulleys are about 3” in diameter but would love confirmation from someone.
DiverseThinker
11
Indian Trail, NC
Searching the TMs for “pulley” I only found references to procedures for repair, replace or maintenance. But I did not find any part numbers. It is possible the 11, or so, PDF files I have, and searched, are not all of the documents and there is another one with part numbers.
Ronmar
7,296
Port angeles wa
You are looking for the 24P manual. That has all the system exploded views and individual part numbers. You can get it up in the tech manual section Unfortunately that part does not appear to readily cross to an off the shelf part. The P/N for the pulley is 12420812 if you google that you will get suppliers of NSN based parts, if you take the cage code you can determine who actually made the part and you may be able to find a comparable that way…
Good Luck
DiverseThinker
11
Indian Trail, NC
Good Luck
Thank you Ronmar for directing me to this. I did submit a Request for Quote for purchasing two of them. I suspect, they will either ignore this or charge way too much for them.
DiverseThinker
11
Indian Trail, NC
If my plans to purchase new pulleys do not work out, the next step would be to try to find an after market replacement. If I can find one, I will let everyone know the manufacturer and model number. If this does not work out, then I will simply purchase pulleys that have a different shaft diameter and have a new shaft welded to the current bracket. I do hope that I can find existing after market pulleys.
DiverseThinker
11
Indian Trail, NC
but there are folk (easier to find on facebook though) that sell parts off non running trucks etc. They are in here too... just not as active
Thanks again Coachgeo, I did not see that your post was a link to someone selling the part. I will attempt to purchase this and have them ship it to me.
Ohiobenz
267
Seville, OH
I've got a like new one if you're still looking.
BERZERKER888
892
Daytona, FL
these are your friends.. especially -10, -3 and 24P
coachgeo
3,407
North of Cincy OH
there is pictures and part numbers from the TM in this thread already
